Results 1 to 10 of 25
Thread: Vic Jr intake with Elbow
    Nov 2006
    Mesquite, TX
    Im not going to use it so figured i might as well sell it...it's powdercoated black and the elbow is just painted black, intake has gaskets in it but i would replace them just for grins as they are cheap anyways...all the mods have been made for vac ports and what not...bolts right on...DOES NOT COME WITH FUEL RAILS....$300obo
    How does this compare to the TBSS intake?
    Nov 2006
    Mesquite, TX
    Well i lost a little bottom end NA but it worked really well when i went to boost....
    If going on NA motor then i would say stick with the TBSS intake unless you have a big stall, but something with FI or Nitrous then i would say go with this...it helps to better distribute the more evenly to keep from leaning out the #7..just what i heard from a couple of builders
    wichita falls, tx
    I'm assuming u can still use factory rails
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
    Nov 2006
    Mesquite, TX
    yes sir, just have to get a little creative with it...i used hose clamps to hold down the factory rails....worked really good
    Summitracing sells new few rails for that intake for $79.
    Mar 2006
    Mesquite
    So they don't have many left?
    Jun 2009
    Dublin, Ga.
    what size t/b does it accept? very interesed to go in place of my fast90.
    '00 Silverado, '98 Trans Am, and a couple other toys.
    Mar 2006
    Mesquite
    Quote Originally Posted by youngun View Post
    Can I have your FAST 90?
    Nov 2006
    Mesquite, TX
    i set it up to run a 78mm with a adapter, but you could also run the 90mm...either or
