installing fuel pressure gauge
to install this fuel pressure gauge. It has the 1/8 sender. Do i just screw that into the passenger side little valve thing after i remove the cap on it pictured here?
then run that wire into im guessing the back of the gauge is where it will go? then im guessing it will have a wire off the gauge for the power and then just put that in a fuse that is controlled by the ON ignition? that should be it right?
2006 silverado 4wd w/5.3 and 4.10's
-blackbear 91/93 tune
-Pacesetter LT's
-flowmaster
-trueflow air filter
Wish list: Comp XR265HR or XR259HR cam, Vig 2800
