Results 1 to 8 of 8
Thread: Budget Edelbrock billet fuel rail installation
    Here's my latest addition to the ride. Since the weather is too hot to improve track times I decided to put the race money to use doing a little upgrade that became necessary when my shraeder valve cracked on my stock LS2 fuel rails. The weight of the fuel pressure sending unit and abuse of the engine cause a crack in the schraeder valve connection. Its a good thing Jon(DBRODS) noticed it when we were at NitrousOutlet or the truck could have burned to the ground due to an underhood fire.
    http://www.ls1truck.com/forums/290913-post2.html
    That looks nice Greg!
    wow and only for $140 dollars. How much more is it for a FP regulator for a return style?
    it would depend on what FPR you bought. You'd have to get it and all the AN connections to hook to it along with hose. I used all 6' of my -8 hose and moved my fuel filter all the way back to just in front of the fuel tank. I figured that if one day I upgraded to a bigger pump, the supply line would be ready for it.
    BTW, the Edelbrock rails are only $79.95 for a set new. Edelbrock 3638 - Edelbrock Aluminum Fuel Rails – SummitRacing.com
    Here's a breakdown of what it would cost new to do it the way I did...
    Rails $79.95
    EAR-165106ERL ALUM TUBE ADPT -6AN to 3/8" $9.25
    EAR-991912ERL -6AN MALE TO -8AN MALE UNION $5.25
    SUM-220890 -8AN FEMALE HOSE END STRAIGHT $6.95
    SUM-230806 -8AN BRAIDED STAINLESS HOSE 6' LENGTH $28.95
    SUM-220887 -8AN 90 DEG SWIVEL HOSE END $14.95 (3)
    SUM-220846 -8AN MALE TO 3/8NPT ADAPTER $2.95 (3)
    SUM-G1487B-1 3/8 NPT PIPE PLUG $1.95 (caps off end of fuel system if no pressure gauge installed)
    $186 plus shipping costs total for a returnless billet fuel rail system
    I forgot to add time to drill new mounting holes plus building the simple mounting tabs out of some strap iron or aluminum. I had some 1.5" square aluminum tubing I cut up to make mine out of.
    The 3/8 NPT to 1/8 NPT adapter was a 3/8 NPT plug , similar to Perma-Cool 15144 - Perma-Cool Plugs – SummitRacing.com , I bought at ORIELLY's for under $4 and then I drilled and tapped it for the 1/8 NPT fitting. If you don't have a fuel pressure sending unit or a need for an outlet at the end of the rail then a simple 3/8" NPT plug will work.
    BTW, the Edelbrock rails are only $79.95 a set new. Edelbrock 3638 - Edelbrock Aluminum Fuel Rails – SummitRacing.com
    That's a good plan stan, getting your system ready for a bigger pump
    Updated previous post with actual new prices for parts.
    Just thinking ahead on the larger hose setup in case I ever want to go bigger. Who knows, maybe an injected Edelbrock/Musi 555 Big block could go in here next.
    Hahaha. Any news on the plate problem?
    Must be something electrical. It flowed the right amount of nitrous during the test. I'll work on that later when I don't sweat a gallon of precious liquids out of my body per hour while working on it.
