Results 1 to 4 of 4
Thread: v8 swap?
    Jul 2009
    In the sticks, Maine
    v8 swap?
    Looking into building a 99up 2wd. Whats required in the swap if it has a v6 and im goin to an 8?
    need a v8 engine harness, v8 mount for the driver side, v8 fuel lines, new engine, PCM tuned with Passlock disabled... its a little envolved but not too bad. Much easier to start with a v8.
    But if you want to start with an RCSB V6 trucks are easier to find and cheaper, if you score some good deals it'd be cheaper to start with a V6 truck. Especially since you really don't really care about the powertrain you could find a high mileage truck and start with it. That's my main dilemna, mine just turned 30 000 miles, pretty hard to find a 6.0 with less then that without going brand new crate.
    hot & windy
    here's the thread that explains just about everything
    http://www.ls1truck.com/forums/v8-co...wap-guide.html
    instead of completely replacing all the fuel lines, you can use compression fittings & braided hose to adapt the 4.3 lines to the V8 fuel rail. see above link for more specifics
    00 FRC - just top end, exhaust, and a hot-air intake
    99 Sierra - 5.3 / 5spd
    ↓ click the pic for the build ↓
