Results 1 to 8 of 8
Thread: Ls2 Short Block
    Austin, TX
    Ls2 Short Block
    Selling my project LS2 engine less the heads. Will remove heads when sold. Engine has 18,000 miles on it when replaced. Has a spun rod, broken oil pump and a crack oil pan from customer running over a rock in the road. It will come with a new pan and gaskets. Perfect for a 408 build. Engine was in an 05 Vett. 24x crank $600
    Back of engine is clutch dust
    5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
    _____________________________________
    2006 2500HD 6.0L Crew Cab 2WD
    Slimsilverado Guest
    Is the block in good shape?????
    Austin, TX
    As good as a new one, I was just going to replace the crank and one or two rods and run it. I'm going to do a 5.3 TO 5.7 instead. Your up North right you can come by and see it.
    Tyler, TX
    about 6 months ago i would have dropped cash on it, but i bought a 5.3L to make a 5.7L out of. so yeah, super deal though
    www.tjc.edu
    Not too certain you can do a 408 using an aluminum block, maybe a 403. You can't cut the cylinders much at all on aluminum blocks, just can hone them out about .005" larger and that's it before they start getting marginal.
    Quote Originally Posted by Jermoslin View Post
    Austin, TX
    Bump, OBO
    GLENDALE,ARIZONA
    How much to ship to 85303
    Last edited by midnight04; 07-19-2009 at 10:04 PM. Reason: answerd my first question...
    Austin, TX
    Sold
