Originally posted by GREG_92_C1500_2001_LS1_A4@Oct 12 2004, 08:38 PM
Start off with a Nelson tune for gas mileage. Change to synthetics throughout the chassis...oil, tranny and rear end lube. Tune up with platinum plugs. Change the air filter to a K&N type filter. If he has wide tires he will need to change back to tires no wider than stock. Be sure tires are aired up to the maximum listed on the tires. Remove all weight that you can from the truck that isn't necessary including the spare tire. Add a bed cover, even a cheap vinyl topper will redirect the air flow over the tailgate or just remove and store the tailgate. If he has those 200 lbs ranch-hand bumpers, lose them for stock ones. Every pound of weight consumes fuel.
FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
OR TO GET ME PERSONALLY CALL: 1-615-943-6514
2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
