Results 1 to 10 of 11
Thread: New guy here.
    Sep 2004
    Pleasant Grove, AL
    Just wanted to introduce myself. Names Kevin. I have a 2000 Chevy RCSB 5.3L. It has an STS Turbo on it running 5.lbs of boost. Best times are 13.8 1/4 and 9.69 1/8. Look forward to meeting all of you.
    Kevin Lucas
    www.gracemotorsports.com
    Kevin Lucas
    2000 Chevy Reg cab Silverado 5.3
    STS Turbo, Nelson performace Tune, Dial boost, 30lb injectors, FLP trans, 2500 stall and Eaton Posi.
    400hp/429tq at 8psi
    San Marcos Texas
    Hey nice to meet you Kevin. That truck is running real strong! Welcome!
    Mar 2004
    Springfield
    Welcome to the site
    Man, I wish I was seeing some better track times from these STS turbo kits. Although they do put down good numbers, I thought a good turbo setup would at least put a RCSB in the high 12s.
    Now, I can't decide if I shouldn't go the route instead. Alot cheaper.
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    I hear you there Kinjo. I am running 9.77 1/8 miles without NOS or blowers and am totally stock except a little aggressive tune. Those turbo trucks should be faster in my opinion. After running a 2004 with a dealer installed whipple I am not impressed with them either. Sounds to me like going all motor is the way to go and maybe a little happy gas on the side when I want to push the limits.
    Apr 2003
    Mansfield, Texas, USA
    Welcome over.
    Sep 2004
    Pleasant Grove, AL
    Whoops! I just notice my typo. I ment to write 8.69 not 9.69. I was running 9.70's with just free mods and a 2500 stall.
    All my times with the turbo were on street tires spinning off the line and shifting into second. Will have slicks on soon. Will get you some good times then.
    Kevin Lucas
    Kevin Lucas
    400hp/429tq at 8psi
    That sounds so much better. Still, I have seen newer Silverados running 8.5s on a near stock motor with a 150 shot.
    Mar 2004
    Springfield
    Kevin Lucas
    Slicks will grab alot better but if you want good solid traction you will have to throw an Eaton Posi on the rear of that baby.
    Sep 2004
    Pleasant Grove, AL
    Eaton posi was one of the first things I did. Had to get rid of that Gov granade. After I do a little sweeking on it I hope to brake into the 12's. I really want it to get in the 10's at some time. We'll just have to see.
    Kevin Lucas
    Kevin Lucas
    400hp/429tq at 8psi
    May 2004
    Welcome, yeah I'm having traction problems myself only at the track though. Smokin both tires off the line sucks for low ET's...Zed
    13.920 @ 98.94mph...[/b]
