I hooked up the scan tool today, and it showed two codes, Knock Sensor 1&2 Circuit Low Frequency. How am i supposed to fix this? What could cause this?
5.3L, 4L60E, True Dual Exhaust, 40 Series Flowmasters, K&N Cold Air Intake, Nelson Performance PCM, 93 Octane, 0% TM, Ram Air Hood, 35" Pro Comp X-Terrain's, 18" Mazzi Sphinx Wheels. 3000 stall Yank, TCI clutches, Trans-go Shift Kit. Soon To Come:
4.56's, Cam, PLT's
It's pretty common for these knock sensors to get messed up from moisture.
I would remove the intake manifold, replace the knock sensors and small harness.
Only way to do it.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
yup...i had to do that about 3 months ago
Yep. Two sensors, one harness (if brittle), intake gaskets (if the old style or high miles), remove the dams from the intake, and seal the FRONT HALVES of the valley grommets with silicone.
its easy,just replaced some on my 03'yukon and buddys 02'2500 hd last week.1 1/2 hour job
remove intake,get ready to clean up a mess under there too.cover the cyl head ports before you clean it.and yes when you install the new ones,put some silicone around the seals that cover the sensors.
what do the Knock Sensor do?
can u delete knock sensors like the 02's??lol probably dumb question.
