Hi All,
i have a Proplem with my 2002,6.0 when it is cold and hot he starts very bad no idle,he start only when i push the throttle pedal a little bit what can i do to fix it??? I have 50 psi fuel pressure at idle. What the best idle rpm i have 580 rpm with aTh 700r4 behind i think it is a little to low?
Scanner reads Code P0134 and P0154
New ones will comming next week...
Greetings from Germany
Hardy
