Anyone running anything other than a tru trac or eaton.
Detroit E-Z Locker 813A023 GM 10 bolts 8.5" 30 splines :eBay Motors (item 260424741759 end time Jun-14-09 12:58:12 PDT)
Anyone running one of these?
Eaton LSD here,, 3 years and a ton of abuse.
2000 ECSB Silverado 12.5@111
1993 RCSB S-10 Stock- for now-
My Eaton LSD was less than one year and dead to the point it wasn't rebuildable, kevlar clutches down to bare metal and one of the axle pinions almost welded to the case. I do seriously race it hard at the track every Friday turning Hoosier drag slicks and am pushing right at 600 RWHP.
You dont hear many Eatons goin out like that. Did you replace it?
When i put the Girdle cover on, mine still looks good. but im not close to 600RWHP,,,,, yet.
Dont have the cash to replace it right now so I stripped the LSD down to the pinions making it an open diff and then welded it solid, making it more or less a spool to get me by for a while. I'll only run it at the track with it setup like that.
im in the middle of taking out my auburn and putting in a eaton with the new gears
2000 GMC Sierra
6" pro comp suspension
3" body lift
2.5" truxx leveling kit
37" micky thompson mtz
pacesetter long tubes-offroad y-pipe-no cats-morroso muffler-MSD coils and wires-flex a lite fans-air aid intake-diablo tune
That Detroit E-Z locker is a design that replaces the side & spider gears in an open differential with a mechanical locking device. It will not work if you have a G-80 diff.
It is designed primarily for off-road use. When it locks, you feel it. When it unlocks, you feel it. Your vehicle noticibly changes directions as this happens. But they work very well off-road(in the dirt/mud).
There is a good reason that all you ever hear about here is the Eaton LSD or the True-Trac. They operate seamlessly, reliably, quietly, and they are proven to be strong. The Auburn **cheaper** cone style posi diff is also weak and is questionable past 350 hp.
2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
