Results 1 to 10 of 10
Thread: P0315 please
    Feb 2008
    Arizona
    P0315 please
    hey guys, I'm sorry, I posted a thread with a wrong DTC.. after beating on my truck pretty bad the other day, this DTC showed up.. P0315.. what does it mean? thanks again!!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    If you've swapped PCM's you need to have the CKP relearn done.
    Jun 2007
    maine
    i have that same code its been on since the beginning lol. is that an issue
    ...you need to have the CKP relearn done.
    +1.
    Feb 2008
    Arizona
    I'm guessing they can do it in the dealer right? in order to erase that code they need to fix the problem? or they can erase it without the crank relearn procedure? cause I don't want them to just erase it without fixing the problem..
    There is a certain process that has to be done. It can be done with a Tech 2 or similar. A dealer can do it, but at a fee--obviously. It might be tricky to have a Crank Relearn done by a dealer with all of your mods and a tuned PCM...
    anyone with hptuners software can do it for you without having to pay for licensing.
    If you put your location in your signature maybe someone in your area may help you out. AFAIK you're in Canada and I can't do anything to help you up there.
    Takes 30 seconds with a TechII and mods won't matter if you don't tell them...besides, doesn't matter when you're paying. I have done them for free for members of this site and the Denali site I'm on sometimes too.
