--'01 SCSB 2006 Full RST Conversion, Built 6.0L HO & 4L80E, **Always Under Construction**
--'07 BMW 335i Coupe Dinan 3.0L Twin Turbo (My DD)
Black On Black
Built Not Bought
my frame mount on the passenger side fit perfectly but the one on the driver's side had to be cut and welded (modified) in order to work. i searched and searched but pretty much everyone told me it required modification. i thought the frames were the same on the trucks and hd trucks/suvs but i suppose not due to the driver's side frame mount modification. i swapped from a 4.3 to 6.0 also. good luck, rob (956) 802-7700.
Get a 34" factory radiator, they're plentiful and cheap at the aftermarket body panel places.
Black On Black
Built Not Bought
where at? Im not really looking for an OEM, id like to get a performance (better cooling than stock) 34" aluminum radiator for a good price if I could find one. Im not opposed to a used one even, as long as it is in good shape and priced good. I do need to get it soon as I am about to swap my motor in and need to install it when I remove the 28" radiator. any other help would be greatly appreciated..
Black On Black
Built Not Bought
Pm me if you want to sell the pcm from your 4.3 i need one since i still have my v6 in my truck and cant afford tos wap right now
RedHeartBeat is refering you to places like LMC Truck Parts: Chevy Chevrolet Blazer S10 GMC Jimmy S15 Ford Bronco Ranger Pickup Pick Up Accessories/Catalogs page 111. And other body sheetmetal websites like LMC.
