traction activated issue
so hears the deal .my escalade ,for the last year is activating the traction on the cluster.when i take off fromm a stop only.and periodically if you hit a bump wile turning ,this part may be normal.but like i said it comes on and slows the truck down till you release the pedal.Any ideas appreciated.I d like to fix this my wife drives it all the time .Its my 03 esky.
