Results 1 to 10 of 27
Thread: 5.3l with harness
    Wichita Falls, TX
    5.3l with harness
    I bought this motor off of a member here(tdk08) and planned on using it in my 80 silvy but have decided to do a big block in it. I tore the top half off of the motor to check it all out and it looks fairly clean for a 125k mi. engine. exhaust manifold bolt snapped off in head, needs all gaskets $350 firm. I don't mind seperating motor and harness if I can get the motor gone first. 250 for motor only.
    Victoria, TX
    Sell the harness seperate?
    2011 4x4 6.2 Silverado ltz 6" fabtech lift 20" XD spy 35" nitto mud grappler
    wichita falls, tx
    wow...350 is cheap!...
    Intro Radicalli's
    good deal to be had here
    san marcos,tx
    What year is the engine and harness?
    Wichita Falls, TX
    the harness is out of an 01 2500hd, the engine is from a 99 Z71. I will sell the harness seperate if I can sell the motor first. I would be willing to go 100 on just the harness and 250 for just the motor. I have $350 in the motor and harness not including the gas and time used to go pick it up so my prices are firm. Thanks for the interest guys, I will try my best to get pics up later today.
    wichita falls, tx
    so that means that harness is for an 80e?....been down that road before...
    Intro Radicalli's
    Victoria, TX
    Quote Originally Posted by banker099 View Post
    take it that makes it a PITA to mate with a 60e?
    wichita falls, tx
    yeah not enough wires in a 80 harness to make a 60 work
    Intro Radicalli's
    Wichita Falls, TX
    but if you are planning the 80e swap it would be perfect.... the trans pigtail is missing anyway so you could always wire in the 60e pigtail and run the wire to where it needs to be fairly easy with the harness on a bench though.
