So what do you huy's think is better, more boost less compression or a little more compression and less boost. All things being equal to get the same power output out of both setups.
If its primarily a street vehicle, I would run the most compression I could that would still allow me to hit my power goals on the chosen octane under boost in the given app. That would give you a more responsive engine out of boost, also more efficient. But, by going on the lesser compression side you have way more room for error with the tune under boost, less chance of timing being pulled and you have the capability to make more overall power with the fuel being the limiting factor. Its all about the particular combo in ? and what your after....![]()
Gen I Viper
Here comes the great debate...
Gone, but not forgotten!
boost
compression should match intended boost level ........... done.
2002 Tahoe 4.8 - soon to be turbo'd - SOLD
1989 Mustang - LX Vert - 351W-TT - 2inches of dust covering it
2012 Raptor - 497rwhp at 10psi
If you aint breaking - you aint going fast enough
There is no answer to this question
Too many variables.
static compression
dynamic compression
aluminum or iron heads
intercooler or no intercooler
type of intercooler
fuel
tune
boost level.
compressor efficiency
ect
ect
ect.
