I pulled the water pump, and the impeller had spun free of shaft that couples it to the gear, it was sliding freely back and forth in the housing. the blades are chewed up and it ground down the inside of the housing a bit.
is this acceptable to use or do i need a housing? also what could cause this to happen, the pump only has 11k miles on it.
that's why I hate them...and the fact they cost so much.
