Results 1 to 8 of 8
Thread: 00 to 03 gmc bumper swap
    Da-Mo
    I recently acquired a 03 and up GMC bumper. I have a 00 model and I was wondering if they make brackets for the swap or am I going to have to do some cutting and welding? I took my factory one off tonight to see if it was a direct swap but it was not. Thanks for the advice ahead of time.
    Wichita Falls, TX
    I think you will have to modify the frame horns and brackets.
    Feb 2009
    brooks, alberta
    interesting...i put an 03 grille on my 01, bolted right in. was thinking about finding a bumper but if its not bolt on il leave it alone.
    2001 gmc 1500HD SOLD...new truck 2004 sierra
    Houston
    ez way to find out is trying to buy and aftermarket bumper and seeying what yrs i will fit if it says 99 to say 05 ur good but if not well then pull out the welder
    2000 Yukon Xl
    2003 Sierra Denali Quadrasteer
    Your Moms House
    Never seen a conversion bracket for the 03+ bumpers. Prob ezer to do a denali front end. Cutting and welding will most likely have to me done.
    Bakersville, NC
    If your going to do it go with a denali or get a ss bumper from street scene and be different.
    David,
    2003 GMC Sierra Denali, LQ4, AWD, AWS, 4.10, Wheatley 93 tune, LT headers, GMPP CAI, BBK 80mm TB, MSD wires, E3 plugs, 160* T-stat, Flowmonster DI/DO, cutouts. Working on 4.8 heads, just purchased Comp 228R cam, 918 Springs, TI retainers, 7.4 hardend pushrods,
    Oct 2007
    weatherford,TX
    Go to dealership and tell they u have 03 gmc and u need the front bumper brackets for the frame , they make they where u cut off your old ones and slide. These on the inside of your frame and drill hole and they bolt on real easy this how they r repaired if there damaged real bad in a wreck
    [SIGPIC]5.3 k&n cai ,asm lt, hf cats, aero turbine muffler, vhp 216/224-551/551-115lsa, tbss intake, ls2 90mm tb,tb bypass, comp double roller tc, hv oil pump, ls2 injectors,nelson tune, b&m super cooler, taylor 10.4mm wires, ngk tr55ix, 373 Detroit tru trac,
    Wichita Falls, TX
    Quote Originally Posted by GenIII_4Ever View Post
    +1
