Results 1 to 10 of 16
Thread: 3 bolt or 1 bolt cam?
    Okeechobee, Fl
    Question 3 bolt or 1 bolt cam?
    I was given a very good deal on a cam kit that i am going to purchase but I was told it was a 3 bolt cam, im wondering if my 4.8 is a 3 bolt or a single bolt?
    Thanx in advance!
    Chad
    49 Ford F1
    Birmingham, AL
    yours is 3 bolt
    01 Silverado
    yup 3bolt,07 nnbs+ are one bolt
    Oct 2008
    Houston
    Did they just start the 1 bolt with the LS3 ? or LS2
    2002 Tahoe 4.8 - soon to be turbo'd - SOLD
    1989 Mustang - LX Vert - 351W-TT - 2inches of dust covering it
    2012 Raptor - 497rwhp at 10psi
    If you aint breaking - you aint going fast enough
    Houston
    sweet! thats a relief i was woried about that i couldent remember what year it was
    Now does the 06 have the front cam sensor or the rear? And is there a difference in the cams?
    If you have a single you can still use a 3 bolt cam, you just got to replace the cam sprocket to match. Or am i wrong.
    Oct 2008
    Houston
    Quote Originally Posted by 6.0vortecchevy View Post
    I dont think its quite that easy.
    I have seen Lingenfilter makes a "kit" to retrofit the cams
    and adapt the cam sensor
    there is a special sprocket you have to get to generate 4 pulses per revolution of the cam versus 2 pulses in the older model. Surely someone already is marketing the 3 bolt 4 pulse cam sprocket.
    Oct 2008
    Houston
    That must be what I saw Lingenfilter selling on ebay.
    They do make a swap sprocket kit too.
    so the cam sprocket itself is smaller on the nnbs.
