How did yall fab up yalls brackets 2 mounts them up?? And would nelsons harness make things super ez for me?
Airaid, alpine double din,
what fans u trying to use?
Man I went total custom with some black wire ties.....
I know it's not what I need to stay with but it is temporary until I get off my fat, lazy hind parts and make something. If you have some good electronics experience and are meticulous you shouldn't need the nelson harness unless you are using some ls1 or factory 05 fans.
Im thinking bout gettin sum ls1 fans or should I go with sumtin else any suggestions
banker has the ls1 fans and says he likes'em, I have the Jeg's universals and I like'em. I've lso seen some other universal setups that I like.
I use flex light the come with mounting ties and I wire them into a wire on the fuse box that comes on with the key
04 1500 5.3L custom hp tuners tune by myself don have a pic of it yet so hear is my old 01 chevy 5.3 460hp 13.669 @ 116
I just found two mounting holes on my radiator support and put a couple nuts and bolts through it and it holds up great. I had problems with the plastic inserts holding the fans up, falling
Well im on a budget n can get sum for 50 bucks 2 12 inch justb wondering how hard they r to install n what to espect of them
It's cake man
I have GTO fans, I used my stock metal end brackets and found exsisting holes in my support. A little loose but they dnt fall so Im good![]()
1993 Gmc 02 ls1 Circle D 3400 stall, long tubes, 220/224 cam stage 3 heads, weiand intake, auburn posi, 389rwhp 352ft/lbs
