Someone posted a link to a billet aluminum part to go on the oil pump sump tube that is supposed to help prevent seal failures. Anyone able to locate the topic? I've searched for over an hour now and can't find it.![]()
NVM, finally found it.
http://www.ls1truck.com/forums/233585-post82.html
Now to find out whom BRP is and a link to their site.
Found it. BRP Muscle Rods Your LS1 - LSX Conversion Kit Specialist
eBay Motors: GEN III and GEN IV LSX engine girdle for PIck up tube (item 260363968799 end time Apr-18-09 09:16:27 PDT)
Ordered one. I'll let you know how it goes. Maybe it will fix my 15psi oil pressure at idle issues.
s10 with 4l60e and cammed 5.3 on the road!THREAD
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.".
glad i could help you out with that![]()
DamnYankee: my nana failed
did it fix your pressure issues buddy?? I'm having the same issue right now
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
just ordered it yesterday on Ebay. If you look at the pictures of their install I understand what is meant by a pinched oring, the tube gets cocked over at an angle and compresses the seal on one side and can create an air gap on the other side. I will definitely be trying it out.
