Results 1 to 10 of 40
Thread: New engine, popping under boost??
    San Antonio, TX
    Hey guys,
    Just got my customers engine installed in the ol truck and I'm having an issue with it.
    I haven't done too much troubleshooting, so feel free to suggest anything.
    The truck runs great under normal and non boost conditions. As soon as it hits a few psi 2-3, the truck will start to backfire or pop out the exhaust.
    Now when I first got this engine together, for some reason the #5 piston blew a head gasket. I immediately replaced it and now it's back in action.
    I gapped the plugs at .025, probably closer to .023 so the 9.5cr doesn't blow the spark out.
    Like I said I haven't done anything else, but I figured I'd post up and go through the troubleshooting stages and share.
    I guess tomorrow, the process is:
    Check plugs for consitency
    Compression check - engine can't be hurt, too soon and not any hard runs on it.
    Make sure gasket didn't blow again
    Change out coils
    New plugs
    The tune is good enough to not cause anything , so I'm counting that out.
    any suggestions?
    thanks,
    allen
    Spring, Texas
    Hey guys,
    Change out coils
    New plugs
    any suggestions?
    thanks,
    allen
    I would say it sounds like plugs, wires or coils. Is there any wires that have been nicked or boots that aren't seated all the way? Are you using the stock coils?
    San Antonio, TX
    Quote Originally Posted by ramair2002 View Post
    ...stock coils?
    using stock coils, but i'm going to try a set of msd's tomorrow.
    Valve float, broken valve spring, poor sealing valve seat, cam advanced or retarded, low fuel pressure, faulty MAF (if MAF tune), CKP failure, loose reluctor, incorrect reluctor....
    Oct 2007
    Bandera, TX
    i say some plug wires burned on the turbo manifold.....like mine did on us.....lol
    single digit street truck
    for build info
    wichita falls, tx
    i have the exact same problem but mine goes completly away when my motor warms up so keep us posted
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
    Bad valve springs? Weak? Wastegates popping early?
    San Antonio, TX
    valve float at 4krpms and 3psi with good springs, probably not, but i'll check the springs, a bad spring could cause valve float.
    could be poor sealing valve, i'll check that.
    cam in straight up, runs too good under no boost conditions.
    fuel pressure, rock solid! a1000, -10 line everywhere, aero fpr.
    no maf
    i hope it's not ckp or wheel, that would suck!
    i don't think it's the wrong wheel, it would backfire and spit randomly and a lot more often.
    Quote Originally Posted by TurboMic View Post
    changing those tomorrow.
    Jan 2006
    Do you remember when you had mine on the dyno? It ran good until you got on it and started sputtering. Turned out to be a burn plug wire.
    no maf
    12 Sec. Club! SOLD
    SOLD***
    fuel pressure regulator?
