Results 1 to 10 of 25
Thread: Cutting stock coil springs
    Aug 2004
    Magnolia, TX
    don't want the front sitting as low as it is. want to cut the stock springs to give a 1-2" drop. any guidance on how many coils to cut off?
    cut one coil.
    59 chevy apache>old school rod with 5.3.
    92 chevy swb>full frame, bagged, 98 interior swap.
    02 chevy swb>LT interior swap.
    01 tahoe> lowered on big wheels, family ride.
    97 ford diesel>big turbo,injectors,oil pump,etc.
    85 stang coupe> black on black, H/C/I.
    Slimsilverado Guest
    zero just buy some drop springs
    Dec 2005
    Houston,TX
    Roughly 1 coil = 1"
    00' Ls1, TSP 228R - 228/228 .588/.588, Yank SST3200, Nelson tune, Nelson wiring harness,
    s&p headers, custom radiator with e-fans,
    91 sub front end with billet grill and bowtie,
    autometer gauges, red and grey tweed interior, dual 2.5" flowmaster super 40, Dmh cut outs, 5"-7" drop,
    air shocks, 20" Intro twisted vistas, gaylords bed cover
    Coming soon: Air ride with an SD raised front crossmember and 6 link canti out back
    San Marcos Texas
    Maybe add a spacer to the springs you have now?
    Aug 2004
    Magnolia, TX
    Quote Originally Posted by Slimsilverado View Post
    already has some on it, sits too low for me.
    Quote Originally Posted by GMCwantsLS1 View Post
    i thought about that, gonna look again today
    Jan 2007
    1/2 coil = 1 inch but it isn't linear. Usually 1 1/4 coils = 3 inches and 1 coil = 2 inches. Since you're wanting an inch or so I'd say 1/2 coil and let it settle.......and use a cutting wheel.
    Just a 4.8.......
    blownwhite03 Guest
    Question cut coil springs?
    Im having a similer problem I have belltech 3" drop springs . Its too loose and mushy bottoms out when I drive it hard. Can you cut stock springs ? Will they seat properly? Safe? How about shocks any suggestions ? I got belltech nitro shocks they suck bad .anyone run QA1?
    Hanford, CA
    Ive seen the stock spings cut and was just fine. Just dont use a cutting torch. Use a cutting WHEEL so you dont over heat the spring and cause fatigue which will make them sag lower and un even.
    '01 Silverado ECSB - 5.3L, K&N, BONE STOCK(For now) 7.5'' Fabtech Lift on 20'' KMC XD's wrapped in 33'' Micky's
    '72 C-10 SBC - 5.3L, 4L60E, MSD, K&N - still a work in progress.
    My 92 actually rode better on a cut coil spring than on an engineered aftermarket spring.
