Results 1 to 10 of 13
Thread: Dyno tuned the 4.8
    Oct 2003
    Dyno tuned the 4.8
    Went and had the truck dyno tuned today in conway at Carolina Speed shop. We didn't run it above 110mph which was a little over 4000 rpm. We were concerned with the drive shaft. So the number are a little low.
    Motor is a 2000 4.8 5 speed with 35k miles
    Mods-
    TR224 on 112lsa
    LPP long tube headers, no egr
    K&N intake
    Custom tune
    Got 272HP at 4000rpm and 361 ft lbs of torque at 3950.
    Whats everyones thought on the driveshaft? Is it safe to run it up to 140 mph to get it up to 6000 rpm where this cam will make its power?
    Pittsburgh, PA
    i have never seen a 4.8 mke that much torque. i seen 5.7s not make that torque
    also why is your AFR so lean?
    just curious tho
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Oct 2003
    just curious tho
    You can't really tell in the picture because of the color, but its at 13.5 on the final run.
    Pittsburgh, PA
    even then thats lean for a LS motor but if it works let it work. im still shocked by the torque
    412 Motorsports
    Yeah....I'm shocked by the HP and the TQ.
    And George, not only did I see your Pinks episode again this evening but this topic brings up an opportunity to clarify a previous post of mine....I see now that you were quoting OEM flywheel rated HP for a 4.8 (275) I was talking about wheel power. Funny since this modded 4.8 (big cam for a 4.8) is just under 275 (remember we were talking stock) when my 4.3 made 163 HP on a 170 rating....LOL....it made 215 or so TQ which is near what a stock 4.8 makes.
    I think this 4.8 has a 75 shot on it 'cause a 75 would add near 75 HP and about 150 TQ at the wheels.
    Oct 2008
    Cedar Park, texas
    wow, cant wait to start building up my little 4.8
    Axekick tuned, Pacesetters, Servo.
    San Antonio, TX
    The HP sounds about right, even if you string it out, you might hit 300hp, that would be nice!
    As for the torque, that's a lot!
    You mention a/f ratio is "lean" , I agree with quik, that's ok.
    If you knew how long GM's calibration ran their engines lean you'd be surprised.
    HD trucks are the worse, but you know what, they live for a long time.
    When I dyno'd this Project 4.8L, it was 14.7 through the entire run, that's GM for you.
    I set this one at 12.9.
    thanks for the info,
    allen
    Oct 2003
    allen
    Allen do you think that the tq is accurate? There a few people on other forums questioning it saying its impossible for the 4.8 to make that?
    Pittsburgh, PA
    id say minus 100 and torque is right
    412 Motorsports
    San Antonio, TX
    Quote Originally Posted by fbs2s View Post
    I could be wrong, likely lol, but that is a lot of torque for a cammed 4.8L.
    Even a cammed 5.3L won't put out that much.
    Look at this, a procharged 5.3L - given, not 100% yet, but...
    http://www.ls1truck.com/forums/dynod...rocharged.html
    take a look at the second cammed 5.3L dyno chart:
    http://www.ls1truck.com/forums/dynod...no-graphs.html
    matter of fact, the supercharged truck above that 5.3L.
    Might want to get a second dyno reading, from a different dyno. Unfornately, they are all different.
