Results 1 to 10 of 15
Thread: 1996 Chevy 10 bolt
    Mar 2007
    McKinney, TX
    1996 Chevy 10 bolt
    hey guys my question is if i switch in a 6.0 lq9 into my truck with a tr224 cam, bigger injectors, full exhaust and tune do i need to update my 10 bolt rearend ?
    Thanks
    Tye
    ChevyLee is running a 14bolt in his, you should ask him because he used to run the 10 bolt
    Pittsburgh, PA
    if the 10bolt has an actual limited slip then youll be fine for little while.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    update the carrier to something like the trutrac. Dont risk killing the carrier, gears and possibly transmissions when the carrier breaks.
    Mar 2007
    McKinney, TX
    alright, because if i switched to a 14 bolt or even 12 wouldnt that change my lug pattern ? i do have a posi rear end but if i update the carrier it will be able to handle that power ?
    Jun 2007
    Ocala, Fl
    truck in sig has factory 10 bolt, with richmond 3.90 and a trutrac diff. with a t/a girlde cover. im selling the guts out of it as im buying a 454ss rear end off a friend. PM if you your interested
    96 c1500, stock suspension, stock bottom end, 93 octane, street radial- 1.60 11.5 at 115- on the small stage-sold
    05 SSS 2wd 228/230/80e/fti4k/5,5drop/215shot-sold
    90 350ss... beast build
    Hope Mills, NC
    try to upgrade. i grenaded my factory rear in a week after i put 400 hrsp in front of it...
    2005 GMC RST *sold
    2006 Silverado SS with nawz
    Jun 2007
    ive got an eaton unit for ya,i just took out my 10 bolt and installed a 14 bolt.
    Jun 2007
    Ocala, Fl
    Quote Originally Posted by turbo4.8 View Post
    was yours stock, maybe not built right?
    i have hit mine with a huge shot of nitrous and still no problem. my 11.5 was street trim on a baby 150 shot. i dont claim my other time, but the 10 bolt is just fine if done correctly. i wish i had axles though lol
    San Antonio, TX
    Still running the 10bolt in mine, until it breaks, but you know what, it still hasn't hahah, after all this abuse. Rearend has close to 250K miles on it.
    It does has upgraded parts in it though.
    it'll hold for a while.
