Results 1 to 10 of 19
Thread: Can't spin the tires
    Jun 2004
    West side of Houston, Spring Branch
    I am running 2001 1500HD CC 6.0.
    3.73 posi trac
    headers
    Cat back exhuast 2-7/8 true duals
    FIPK
    Nelson duel fuel tune
    In 1st gear and power braking the truck, no matter what pavement conditions (other than wet) the truck will not break the tires loose. I have P275/R65 tires on the truck. Is the truck just to heavy?
    2005 ECSB 5.3
    Sep 2003
    Mukilteo, Wa.
    I'd change the gears to 4.10s, first of all.
    Anyone else?
    '05 Tahoe 2WD 5.3
    Performance Mods: Nelson tune, 4" Volant Exhaust, Dynatech Full Header system, Volant Cold Air Intake, TB Bypass, 305/50R20 Eagle GT IIs
    Appearance Mods: 20x8.5 American Racing Torq-Thrust STs, Billet Emblem, Black Chrome Speed Grille, Removed running boards, door guards, fender caps and badges, and Silverstar lowbeams and fogs
    Cardomain Page> Click
    Jun 2004
    That's a good idea, I saw a set sell for 50.00 this week. I am also going with the 93 hot tune in the next couple of weeks. I guestimate that I am running about 325 FWHP. I may need the gear and more HP?
    2005 ECSB 5.3
    Jun 2004
    i assume you have an auto tranny,if you want to break em over you prolly gonna have to go with the 410's and maybe change to a diff torque converter and go with the 93 tune that i think you have already in the works.my 02' seems to have more torque and hp than other trucks its size and diff year for some reason.it doesnt leave a long burn out but it does leave some rubber down even with these 33.5s and it is as heavy as yours as they are the same truck accept diff years.
    admin please delete this acct....
    May 2004
    Well, one problem is you have a very good rear "disc" brake. Not like the the drums of old. Overall it is a bad idea to power brake em' with rear discs, it will destroy your tranny if anything.
    Your best bet to lite em' up is to just punch it from a stand still.
    =Dave
    Jun 2004
    Never thought about the rear disc. Sounds like:
    4:10 gears
    Stall converter
    93 hot tune
    For about 1000.00 bucks I should be able to destroy the tires at will?
    2005 ECSB 5.3
    May 2004
    I know that all it took for me was the 93 tune! I have FIPK2,Flows,93 Nelson(0 TM),Transgo+vette,cooler and 3.42's(will be 4.10's thursday) and before the Nelson tune I couldnt spin tires but with it I can do it almost anytime and I know I will be able to at will with the 4.10's. I know your truck is a little heavier than mine and you have headers so the 93 will do the trick and the 4.10's will melt them!
    03' Silverado EC--LS1-4.8 Heads, Truck Intake, K&N FIPK II, Flowmaster 50 Series, 4.10's, FastChip Tune, Free Mods, Taylor Thunderbolts, TR6's, B&M Supercooler,Transgo Kit,Vette Servo, Ported TB, 160 Stat,Comp 212/218 Cam,Comp Pushrods, K-Motion Springs,TNT F-1(100 shot)
    Projects: LT1 Fans w/Harness,LS1 Intake,Vette Covers,
    LS1 Injectors
    -----------O & A Party Rock--------XM 202------------
    Removing torque management is a must but you better beef up the tranny first or you will be getting a rebuild pretty quick.
    Jun 2004
    I have the 4l80e trans. Do you think it will need to beefed up? the dual octane tune that I have now has all tm removed.
    Tigerfan, where did you purchase the 4:10s
    2005 ECSB 5.3
    Apr 2004
    3.73 posi trac
    headers
    FIPK
    I wish my Trans Am had that problem, I can't hook unless I use E/T streets.
    And if those 3.73 will fit my 1500 CC NOT HD I'll take em when you get your
    4.10's.
    mostly stock 04 silverado 1500 CC
    Gibson Headers and Sport truck Cat Back
    5.3L 3.73 Detroit True Trac
    165F therm,HpTuner
    07 17" Sierra wheels
    Dark Grey
