Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 81
Thread: Guess my total HP!
    Jan 2006
    Guess my total HP!
    Went to Allen's to pick up my truck! Allen had a problem with the fuel delivery. He said at 10 psi and the upper 4XX hp it was running out of fuel. That is insane! So he is going to keep the truck a little longer and put an A1000 fuel pump on it!
    Any guesses on the final wheel HP?
    I'd say 510hp?
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Add the gear ratio to the signature and I'll guess.
    Jan 2006
    373 with an 80E trans.
    And that was only 5000 rpms!
    12 Sec. Club! SOLD
    SOLD***
    550hp.
    What does your fuel system consist of before the A1000?
    Oct 2007
    Bandera, TX
    527
    single digit street truck
    for build info
    Mic stole my EFFIN' answer but I wanted to know the gear ratio.
    Are the fuel pumps wired with a hotwire kit, 10 gauge wire directly from the alternator to the fuel pump through a relay? The relay could just provide ground if thats how you wanted to set it up.
    OK then....
    528
    OK then....
    528
    didnt know we were on the price is right... haha
    make sure they get some vids of the dyno runs james
