Results 1 to 10 of 10
Thread: textured plastic painting????
    im finished debadging truck wanting to color match. question is what steps should i take to paint textured plastic parts?? thanks
    Mar 2006
    Mesquite
    Krylon Fusion in a rattle can...at about any hardware store...works great.
    do i need to prime first
    use Bulldog adhesion promoter on the bare cleaned plastic.
    May 2006
    Waco TX
    I wouldn't paint over texture. It look 1000x better if you remove the texture. To do so you do this
    -red scothbrite the plastic
    -Spray Bulldog adhession promotor on it
    -4-5 coats of high build primer
    -let dry 2-3 hours
    -sand the primer with 320-400 grit or until al texture is gone
    -preclean
    -tack off
    -seal it
    -base it
    -clear it
    And your done. Perfect product.
    Dec 2008
    Amarillo, TX
    where do you get factory matching paint in the spray can?
    '08 Silverado Ext Cab 4x4, 5.3L, 3.73... K&N FIPK, Bully Dog, GM Performance cat-back exhaust, Removed rear block (leveled), KMC Badlands 18x9 with Cooper Zeon 285/60
    Dec 2004
    San Antonio, TX Area
    Quote Originally Posted by Red03SilSS View Post
    -let dry 2-3 hours
    -preclean
    -tack off
    -seal it
    -base it
    -clear it
    Cool. Thanks.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Mar 2006
    Mesquite
    Daniels way is obviously the best...
    My way works if you're lazy and don't want to spend that much time and you only want to spend a couple of bucks.
    I painted the lower valance black (was gray) months ago and it's held up really really good. Didn't really do anything to prep it, other than wipe it down to get any dirt or grime off.
    Just depends what route you want to go and how much time you want to spend.
