Results 1 to 10 of 11
Thread: Need A Little Info On My Cam Swap...
    Question Need A Little Info On My Cam Swap...
    Ok Guys Im Going To Be Installing My Z06 Cam Soon On My 08'BLOWN 4.8,just Wanted To Ask If I Need The Ls7 Cam Sprocket??ive Heard Of Guys Having To Change That On Nnbs Trucks?
    What About Pushrods?
    about how much horsepower is this cam going to give me?anyone seen dyno gains on this??
    I Know I Need The Yellow Springs As Well...
    Thanx For Info..
    Nov 2006
    Mesquite, TX
    If its the older LS6 cam from a 02-04 vette then no you dont need a new spocket you already have the LS2 style one...i would go ahead and get pushrods and maybe do a better spring like a 918 or a PRC spring
    the newer engines have a center bolt to retain the cam similar to Gen1 engines and have to be replaced with the three bolt style of the LS6 cam.
    Quote Originally Posted by mean05 View Post
    GREAT!!yea is from a 04'zo6,yea thats what i was thinking on getting something better than stock z06 springs.ill do pushrods as well.
    by any chance,would you happen to know what i can bump my shift points to??right now im shifting at 6000 rpm.ide really like to shift higher if it would help.
    and have you read on any actual hp gains with this cam swap,mine being f/i ?
    thanks again...
    Nov 2006
    Mesquite, TX
    thats on the 6.2 and 7.0 right....they didnt do that on the 4.8, 5.3 or 6.0, they still have the 3 bolt with the LS2 style sprocket and cover
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by chevrolade View Post
    thanks again...
    people rave about this cam with FI which is why i went with this cam for my TT setup...right now i have mine set at 6200 1-2 6100 2-3 6100 3-4, i am going to bump it up later cause of the vic jr intake i am running....i would put it on the dyno and see where its making the power...that will tell you the best place to set the shifts at
    You may be correct. I can't say for sure since I haven't done a cam in any 07+ setups. I remember one being posted about changing the sprocket. Might be a good topic for a writeup if someone can find the documentation. Nathan?
    oh man i didnt kno you were running this cam,good to know,please keep me up dated.
    one more thing these are the 7.425 pushrods that i need right?
    thanx for your info,appreciate it
    features .550" intake and exhaust lift, 218 degree exhaust duration and 204 degree intake duration at .050", and 117.5 degree lobe centers
    those are the specs,would it help if i threw some roller rockers on top of this??if so what ratio?
    Round Rock, TX
    The 6.0 (LS2)in the 08 TBSS has a single bolt in the center sprocket for the cam.
