Just like the title says. Looking for a 4L80E...Any out there ?
Slowest in Oklahoma...
If you want the best and are willing to spend the money. Go here. Finish Line Transmissions | Performance Transmissions | Torque Converters | Transmission Parts | Transmission Service
That is my future plans. Right now i was just looking for a normal one so that i can make the brackets and get everything working. Then up grade to the FLT.
stop stealing my ideas faggot![]()
I have 3 just sitting in the back yard just come get one ......... Ahhhh just bullpooin ya !! Good luck on the search and if I were you I'd break lambo's neck for that coment !!! Just my 2 cents....![]()
Just did the swap myself. Hoping a stock one with SK will go a long way.
03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
Thats what I'm running, Transgo HD2 kitted 2002 model and its survived the 408 and 300 shots until a low roller clutch set failed. I have yet to find a performance replacement for that setup yet. With S/C your 80e should last a very long time.![]()
80e is nice, but the stock stall is a power robber. Right Greg?![]()
Stock stall makes the truck miserable to drive.... I was going to run one in my truck after my swap and WCCH made me promise that i get a nice stall so the truck wasnt a total turd...... installed stocker while my PI was out... took 2 city blocks for the turbo to go on boost..........KC
