Results 1 to 7 of 7
Thread: Need some transmission help
    houston texas
    Have an 84 silverado with a th350. I have a 700r4 out of a four wheel drive that would like to put in it if possible, or would i need to buy a th400?? Is there a way to wire the overdrive gear into a toggle switch or something to that nature where you wouldnt need the computer to shift into overdrive?
    2002 silverado with a 4.3l v6 single wheel peel with true duals.......JK, 2002 silverado, KB 5.3 liter SOLD!!!(to a 16 year old for his first vehicle)
    2002 camaro z28 Fully Built LS1, ARP rod, light weight pistons, ported and polished heads, swirl polished valves, titanium retainers,comp roller cam. 85 mm tb. 300 wet shot. ratchet shifter. Bullet proof stage 3 turbo 350. lt headers. 12 bolt 342 posi.
    2008 ford f-150 6" lift 20" motometals 35.5" toyo a/t's
    2008 f450 6.4l tt king ranch cc lb dually 4x4 Bully dog Power Pup.
    A 700 is not controlled by a computer other than the TCC you can wire up yourself. If the truck it's going into is 2WD you'll need to change the output shaft and extension housing to the 2WD style. A 400 is another story all together. It's not any more of a direct bolt in than the 700 and has only three gears like the 350.
    houston texas
    so what would i need to purchase and how would i go about installing the 700r4
    You have lots of topics about this TODAY.
    th400 would take a 99-01 long crank 6L or add a crank spacer, flat flywheel and longer bolts to make it old style. Then you need a larger yoke for the 400, crossmember relocation likely, and possible shortening of the driveshaft. The PCM would need a digital speed signal from the output shaft so you'd need something like a Dakota Digital speed encoder. Next you'd need to wire 12v to the TCC solenoid and a grounding switch on the dash or gear selector to turn it on. Get power for the TCC from the brake switch, the wire that loses power when you press the brake, so it will unlock when you decelerate.
    Bakersville, NC
    the th-400 will be a lot stronger but will also use more gas and take more power away.
    David,
    2003 GMC Sierra Denali, LQ4, AWD, AWS, 4.10, Wheatley 93 tune, LT headers, GMPP CAI, BBK 80mm TB, MSD wires, E3 plugs, 160* T-stat, Flowmonster DI/DO, cutouts. Working on 4.8 heads, just purchased Comp 228R cam, 918 Springs, TI retainers, 7.4 hardend pushrods,
    Rumford,ME
    Thumbs up
    400's are tough as nails. If you can deal with only three speeds?
