Results 1 to 10 of 16
Thread: whats the deal on tranny fluid???
    Mar 2006
    I have an 06 4L60 and it says to use the Dexron Vi or Iv whatever the expensive stuff is.. I have the thing completly drained do I have to use this stuff or is the good ol Castrol Dexron III fine???
    Well, I would use just regular grade Dextron IV. I have always used the cheapy O'Reilly's brand ATF Dextron IV. III and IV is similar, but I would stick with the IV...
    VI !!!!
    See TSB 04-07-30-037D.
    General Motors Powertrain has upgraded to DEXRON®-VI ATF with the start of 2006 vehicle production.
    Current and prior automatic transmission models that had used DEXRON®-III must now only use DEXRON®-VI.
    All 2006 and future model transmissions that use DEXRON®-VI are to be serviced ONLY with DEXRON®-VI fluid.
    DEXRON®-VI is an improvement over DEXRON®-III in the following areas:
    DEXRON®-VI
    Fluid Service Change Interval
    160,000 km (100,000 mi) For Cars and Light Duty Trucks*
    80,000 km (50,000 mi) (Severe Use) For Cars and Light Duty Trucks*
    Clutch Friction Stability
    Improved 100%
    Clutch Durability Due To Fluid
    Improved 120%
    Oil Film Thickness
    Increased 20%
    Fluid Oxidation
    Improved 100%
    Foam/Aeration
    Improved 150%
    Shear Stability
    Improved 200%
    * These ATF change intervals remain the same as DEXRON®-III for the time being.
    No crap...they switched to VI for the 2006 model year???
    Good to know...
    I wasn't sure when it was so I looked up the TSB. There's a lot more good information in that bulletin but I only pasted the info related to this topic.
    Mar 2006
    Thanks, thats why I was curious cause during my reading it said 06, but I know the tranny is basically the same unit.
    It's possible the clutch linings and TCC are slightly different in the 06+ as far as materials go.
    could you pull PNs for a 2004 and a 2006 for the clutch linings and see if they're the same numbers? For some reason I think they're the same.
    Yeah, you're right. They are. Hey, I just follow what the General says....LOL
    Maybe just pull the pn for a replacement rebuilt transmission for the two year models and see if its a different unit.
