Results 1 to 5 of 5
Thread: Can anyone identify these connectors and fuel lines from on my pump assembly?
    Oct 2008
    Hey guys, I've grabbed a L33 out of an 05' silverado for a project swap. I am trying to figure out the fuel and evap lines but the Haynes manual has little/no information.
    Basically I need someone to identify what is what down there. From what I've gathered I have a returnless fuel system, where the filter & fuel pressure regulator is located in the pump assembly in the tank. If anyone can fill in the blanks it would be very appreciated, as I've run into a wall with this at the moment.
    #1 goes to the EVAP canister
    #2 goes to the EVAP purge valve on the engine
    #3 goes to the PCM for fuel tank pressure
    #4 is power and ground for the pump as well as signal and reference for the gauge
    #5 and #6 I can't see good enough. Try another pic.
    On second thought I'll guess. #5 looks like part of the fuel pressure regulator and #6 is the in tank return.
    Oct 2007
    connecticut
    no no no. #1 is the flux capacitor
    #2 is the headlight fluid re fill valve
    #3 is where you plug in your i-pod
    #4 is the etcdhlmn diode 6 and 7
    #5 is...well you dont need to know what #5 is
    #6 is the uh, umm ....finally one i dont know
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Oct 2008
    Thanks Guzzler. #5 is a small nipple on top of the fpr. I believe it controls the diaphram via vacuum. I was just making sure since I can't find much info about it.
