Results 1 to 10 of 16
Thread: 3:23 to 4:10 =retune?
    Okeechobee, Fl
    When I switch gears (which will be soon) I'm thinking that I will need to get a retune. My ? is I had to get a crank relearn the first time I got a tune does that mean I will have to get one again? Also I will be getting a g80 is there a break in process I will have to do or can I get in it and put it to the floor?
    49 Ford F1
    ff_jeff Guest
    Yes. Speedo will be off, and abs lights and ebrake light will come on. My speedo is off by lke 15mph. and I had 3.42's before going to 4.10's Crank relearn might need to be done again, but I doubt it.
    yeah there will be a break in process for the g80...
    you flooring it, the g80 breaking..
    ff_jeff Guest
    werd. he is right.
    Okeechobee, Fl
    I assume the g80 I buy will be used will it still need to be broke in and if so what is the process? Also will I need to install the PCM before/after/during?
    49 Ford F1
    ff_jeff Guest
    Quote Originally Posted by 06 4.8 View Post
    No break in for the g80 Instal the tune after the gears. Heat cycle the gears probably. Just drive arround for like 30 mins. let them cool for a while, drive arround a litle more, let them cool over night and you should be good.
    yeah thats what I did with mine and my eaton. Drove around took it easy and so forth, let them cool, did it again
    Okeechobee, Fl
    Thanks guys so you're saying new=breakin used=nobreakin g80 wise, correct?
    49 Ford F1
    I probably would do an easy breakin anyway just to be on the safe side
    Okeechobee, Fl
    Thanks for all the help guys!!
    49 Ford F1
