Results 1 to 7 of 7
Thread: What mods for spray?
    Feb 2008
    Arizona
    how much spray can my engine handle the way it is?? 100hp??
    Also, what do I need to change on my engine to handle more than that and dont have any problems??
    Thanks
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    I've seen guys running 175 shots on stock engines with a good tune and setup. I would do that myself because I'm adventurous that way. Get a forged shortblock with nitrous pistons and rings gapped for nitrous for durability. It also would help to have new steel backed bearings in the crankshaft to handle the additional forces.
    Nov 2006
    Mesquite, TX
    man i could tell you stories of what the motor can handle...
    be safe run a 100-125 shot and go have some fun with that
    ff_jeff Guest
    Id be more worried about what the tranny can handle. I think it will pop way before the motor does.
    Feb 2008
    Arizona
    yeah.. Im soooo scared about my tranny blowing up.. I might get a 4L65E lvl 5 from FLT.. cause I think that with the cam and lts install, I will nail the s*** of of my stockish tranny.. dont you think so?
    Nov 2006
    Mesquite, TX
    cam and lt's you will prob be okay for a little bit and just dont spray through shifts and it will help last longer
    +1
    Quote Originally Posted by mean05 View Post
    ... just dont spray through shifts and it will help last longer
