Results 1 to 9 of 9
Thread: help please.. ORY fitment...
    Feb 2008
    Arizona
    Hey buds, I called tsp to order the pacesetters lts and the ory, and they told me that the ory might not fit my truck cause of the 4wd.. does any of you have installed a ory on a 4wd truck that can help me out? or how much modification did you make??
    Thanks!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Feb 2008
    Arizona
    bump... pleease.. I need to order them today cause I need them by friday...
    appreciate!
    Surely you can find someone with a torch and bender around you to adapt it to your application. Just order it and start cutting to fit. What I think they were trying to tell you is that it won't just bolt together, a little fabrication skills will be required to make it work in your application.
    Oct 2007
    Bandera, TX
    ya, or find a exhaust shop willing to do it for you.
    single digit street truck
    for build info
    Feb 2008
    Arizona
    Yeah, thats what I'll do.. Ill order them and work on them to fit right..
    Thanks!!
    Yeah, with 4WD, you will have to do some self-fabbing work. It would be nice to have a decent sized torch to heat up the piping and a big pry bar to bend it how you need...
    Feb 2008
    edmond, ok
    When we did mine they hit a little at the front 4 wheel drive shaft and the steering shaft. But my driver motor mount was bad and i replaced that and its better but stills rubs every so often. Now i have the obx long tube headers and true duals so they may be a little different. I also had the exhaust shop heat and bind the driver header a little by the front drive shaft.
    07 GMC ccsb 1500 4x4, front replacment bumper, 285 70 r17 on 17" black helo max 6, Dual flowmasters dumped.
    Feb 2008
    Arizona
    pacesetters lts are supposed to be easy to put on.. I think that the ory is the only issue in the installation..
    the headers on mine fit fine and all you have to do to get the off road y pipe in is take off the trans crossmember- It will sometimes still rub on the front drive shaft, but not enuff to worry bout
