Results 1 to 6 of 6
Thread: ported throttle body
    Deer Creek, IL
    Does anyone know where you can get ported throttle bodies at. Who does them? Is it possible to do it yourself or just as simple to have it done? What do they usually cost?
    Thanks
    '03 Z71, cranked torsion bars, AEM Brute Force air intake, magnaflow dual exhaust, Superchip Reprogrammer, 285/75R16 Maxxis Bighorn MT's, lots more to come
    The guy I would use is Mark Shaner. He sells them on LS1Tech I believe.
    anyone ever see any documentation that porting a tb makes any more h.p? i hear to many complants of idle quality for any minute gain to be had. i did a bbk 80 on my truck and it didnt make a damn bit of difference other that it would try and stall every now and then. when i took it for a retune, allen told me it was common. so after no diff and stalling it came back off after a thousand miles.........
    2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
    S.A. Texas
    I put on my 80mm bbk and nelson was able to adjust the idle and its been running good ever since. I doubt you would see changing from the BBK to a p&p stock tb. just my .02
    sprayed99 Guest
    my TBSS hogged out TB works great!
    I hae heard good and bad about ported stock TBs...but the reviews depend on the quality of job done. My 80mm BBK installed easily--and since mine is cable driven, I just adjusted the throttle screw and it idles fine. I noticed a pretty big improvement in power, but then again--I installed it at the same time I did the efans. After the install, I went out for a quick spin and spun em from a dig through second gear...but before the efans and BBK, I could only spin them almost through first...
