I'm about to start my engine swap and had a few questions.
1. Is this the correct fuel pump I'll need and will it work in my original tank?
eBay Motors: WALBRO 255LPH FUEL PUMP Buick Grand National Regal GN (item 180285180485 end time Sep-09-08 21:09:21 PDT)
2. I've heard the truck oil pan hangs down past the crossmember and I'm planning on an air ride system and laying frame. Is there a shorter pan I can use that will still clear the crossmember without moving the engine farther back?
3. The guy that has the engine I'm looking into says he can instal an LS1 intake and is recomending it but i'm wondering if the gain in horsepower will be worth any loss in torque. This is going to be my daily driver and will probably not see much high revs.
4. Heres a list of everything it comes with, He's asking 2850.00 Does that seem like a fair price?
2005 L33 Aluminum Block 5.3L Engine rated at 310HP stock, 21K miles
LS1 Intake with MAP Sensor installed and EGR Block Off
Original LS6 Cast Heads (stock on all L33 VIN B option engines)
LS1 Fuel Rail and 26Lb Injectors,Stock Oil Pan and Exhaust Manifolds
4L60E Flywheel,Brand New Delphi Mass Air Flow Meter (MAF)
Air Conditioning Compressor,Power Steering Pump
Alternator,Starter,Throttle Body.Stand Alone Engine Harness already made for any Engine Swap(4L60E, A/C and Electric fan and Fuel Pump Relays are included in the harness. No Emissions[no EGR, No Evap, No CAT Rear O2's])
PCM Engine Accessories already assembled and idler puller relocation kit mounted.Brand New LS1 Water Pump.160 Degree Thermostat
Thats all the questions I can think of for now but I'm sure I'll come up with some more. This site has been a great help so far. Thanks
