Results 1 to 10 of 15
Thread: My buddies 69 Camaro times!
    Jan 2006
    I was reading a post that one of our members of Brazos Valley Streetbeasts posted:
    "wow no WOW! best quarter mile pass was a 9.86 @ 105 mph......and that was lifting at the eighth!!!!!!!!'
    [IMG]file:///C:/DOCUME%7E1/User/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
    Can you believe it, I can.
    "when you squeeze it that tight its out of gear at the eighth!i think the converter is going south because it was'nt 60 footing as good as i would have liked!1.32 60' and it went 5.90s at 117 in the 1/8 !never had any talent but i promise i'll never run out of balls!!!jr phillips got it on vid,when i get it i'll post it!"
    This is one sick Car! It is primered black 69 Camaro with a medium sized hood scoop.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    ff_jeff Guest
    double post FTW!!!
    Jan 2006
    Must of hit the post button twice?
    12 Sec. Club! SOLD
    SOLD***
    Mar 2006
    Quote Originally Posted by Jamest View Post
    Jamest
    I must be dense cause I just dont understand this post?? Seems like there should be a post ahead of this one that you are quoting?
    That is a super low MPH for a 9 second pass.
    Jan 2006
    He was coasting thru the 1/4 mile. It is an 1/8th mile car. He ran it all out on the 1/8th and then let off.
    He is trying to get the video up.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jan 2006
    I cut it out.
    Here is the direct thread
    Brazos Valley Street Beasts :: View topic - prarie hill?
    Quote Originally Posted by -HIC- View Post
    12 Sec. Club! SOLD
    SOLD***
    Mar 2006
    Heh, I get it now!
    Mar 2006
    They mention Navasota.. I thought that track closed down?? Is it re-opening?
    Thats not too bad. It takes nothing more than a big block and good suspension to turn those numbers. NorthstarDragway has gobs of trailer queens running in the high 5s. It makes me sick because I can't get into the 6s.
