Results 1 to 10 of 25
Thread: Badass Nitrous System w/Stand Alone F/S
    Nov 2006
    Mesquite, TX
    well its about time to go a different route, i love nitrous and the kind of torque it makes but i want something different never have had a turbo and the only way i will change over is to sell the nitrous and be slow so i will be forced to buy the turbo kit so here it is.
    Nitrous Dave's plate kit, has the big boy solenoids and the plate is a single stage plate that was made into a 2 stage plate can handle a 250 shot, 2 nitrous solenoids and 2 fuel solenoids all needed lines, buttons, WOT switch, Relays, everything is here including a 15lb bottle (sticker will be removed) and an 860° bottle heater bracket...
    Stand Alone System was built by LG Motorsports so you know its the best of the best this kit was on my friends 06 zo6, it made 815rwhp with this stand alone and the same kit i have on the truck....the kit comes with 3/4 gallon aluminum fuel cell, Bosch inline pull pump rated to 700hp, Aeromotive FPR, all line are there, the system is setup at 58psi but you can set it however you want...
    Asking $1,300obo everything is in great working order and will be off the truck after this weekend
    this was right when i got the heads and stuff on before i cleaned it up, but you can see the plate has 4 lines going into it for 2 stages
    And FWIW, Nitrous Outlet tells me the plate will handle spraying at least a 400 shot. I'm pushing 300 through mine.
    your gonna love boost..
    Jan 2005
    Humble/Houston TX
    i was told the same thing not long ago. how much would a stand alone system like that set me back? ive never looked into stuff like that.
    old mod list: H/C/I/N/E/G 408
    A standalone using a Walbro is $600, about $100 more with the Bosch pump. I think HarrisSpeedworks sells a universal for the $600 figure.
    Harris Speed Works :: Fuel Pump Kits & Fuel Injectors :: Nitrous Stand Alone Fuel Systems
    Nov 2006
    Mesquite, TX
    there is about 800 in this system, the cell is custom made and the regulator is a very nice high dollar one
    There is no doubt that your fuel cell has better quality parts.
    Sold Bitches, Back Off
    If you buy that you better buy an 80e to put behind your engine or a fresh 60e will be puking its guts on the ground with the way you abuse transmissions.
    hahahah well i really havent decided to go flt level 5 65e or have danny's dad jerry build me one but it should hold up at least i hope
