could be a dirty injector ,bad fuel pump.check your fuel pressure then drive down the rd with the gauge on youre windshield and see if it loses any.ive had terrible luck with warlboros,and refuse to use em .alot of guys like em but ill never use 1 again.check all of youre connection going to the throttle body also ,mine will act like that when ive blown a fitting of my s.c. going to the tb.process of elimination,check fuel pressure then let us know.
