sorry too hear that ,trannies suck,ive beeen through 7 .and i got the whole flt scmeel too.when this one goes itll be a 4l80 conversion.the other day n pt.net someone was trying to give a 80 away from flt for like 2200 .check it out.maybe itll help you save a few bucks.good luck its probly a waste of time for you to try too change converters if your slipping.jmo and expierience with these things.if the coverter blew it sent metal through the whole tranny anyway.but good luck.
