Results 1 to 2 of 2
Thread: pistons
    wichita falls, tx
    pistons
    so im am building a 6.0 and am going to put in new piston and i was wondering what yall guys thought. its going to be supercharged so should i get a flat top piston or a dished piston i would like to run about 10-15 #'s.
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
    Depends on how much boost you're planning on running. If you're only running 5 PSI then a -8cc piston dish should be fine but if you're going for more boost than that get the deeper dish pistons.
