Results 1 to 5 of 5
Thread: flywheel trouble
    Mar 2004
    KY
    my truck makes a odd noise like a ringing or banging under the truck around the flywheel. When i put it in gear it gets more noticeable, and my truck hesitates tot ake off. It kinda shakes a little bit and feels like the brakes are locked up but they are not. what could this be, and how do i fix it?
    96 Silverado rcsb
    5.7l Vortec
    Exterior: 2 inch drop shackles, Centerline Titan 20" Wheels, clear lights, Debadged.
    -Exterior to come: 2-4 drop, Tinted windows, Cowl hood, Green Calipers
    -Performance mods: Flowmaster True Dual exhaust
    -Performance to come: Tune, CAI, Cam, Spray, Posi, gears, stall, headers.
    Ouch, sounds like you blew the torque convertor.
    San Marcos Texas
    It could be loose bolts on the converter to the flywheel. The noise could be triggering your knock sensors and cause the PCM to retard timeing(the hesitation you are experencing).
    if it sounds like a marbles rolling around in the dryer you have destroyed your torque convertor. Only way to be sure it to drop the tranny and first check the flywheel around the center bolt holes for a crack. Otherwise it's a sure bet you killed the vert.
    Dec 2003
    if you broke the fly wheel the truck wouldnt move. My buddie broke a stock fly wheel he had ended up having to have 2 of them welded together for strength
    old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
    New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
    future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
