The VHo's have a 14 bolt 6 lug and the SS's? 14 bolt, 9.5 ring gear 6 lug.
Jamest
Originally Posted by
DBTBSS
Greg, he used the plates with the 14 bolt and I'm confused on the brake pattern your talking about
. To the OP, I think the rear end Greg has is what you need. I THINK (not positive) the 14 bolts of your year model are 8 lug, but the axle will fit without having to relocate the perches. I don't know that they came out with a 6 lug 14 bolt in 03-06.
DOH! This is pissing me off not knowing for sure now, I'll have to go find this out for sure.
12 Sec. Club! SOLD
SOLD***
