puttin in a z06 ls6 cam in a 99 4.8L do the valve springs have to replaced. if they do. are they a factory replacement? or do have to pull the heads to have them machined?
yes, they're cheap enough, about $60 for a full set from sdparts.com . No need to pull the heads, you can swap the springs in the vehicle with the correct tools.
I have a question about this cam also. what push rods do i need for a 2002 zo6 cam?
Step 1. crus at it.
Step 2. get a hammer.
Step 3. torch it.
7.4 pushrods for the ls1... and if you get a ls6 cam they should be a little longer.
most people just run the stock 7.400 length pushrods.
No machining required for the LS6 yellow springs. I just pressurized the cylinders on my 5.3 and changed them like that. I wouldn't trust any stock LS1 pushrods with this cam because I heard they have a tendency to bend at higher RPM/spring rates. Some chrome moly stock length rods will do fine. Make sure to get your ECU reflashed for the cam and for the tranny to shift at higher a RPM
Now sence the cam has a .050 smaller base circle would it be more benificial to use 7.450 lenght push rods?
Step 1. crus at it.
Step 3. torch it.
its only .025" smaller on each side
Step 1. crus at it.
Step 3. torch it.
