Just wondering what people are doing about adapting obs oil coolers to lsx engines specifically lq4. Have you used a block off plate or used new style coolers?
I used the block off plate when I first started my engine (just because I was in a hurry to hear it run)...then I attached the hard lines from the LQ4 oil cooler adapter lines to the old 1986 C-30 7.4L oil cooler hard lines with compession fittings. (Used the old neopreme lines from the 7.4).
I bought a blockoff plate from dealer....dont forget gasket and bolts!
86 C10 6.0/4l80e
you guys talking tranny lines?
'86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
O.K. I'll ask... Is/was their a engine oil cooler option on LS1 or other LS based engines? What vehicle(s) or engine(s) was this on? Where, on the block would they connect? Where does one buy the cooler/adapter/lines? Never heard of this.
Yes...all the HD trucks I've seen have them. My 2000 2500 6.0L had an oil cooler. There's a machined spot on the block just above the oil filter with the feed and return holes in it. Cars have a block off plate there.
If you want I can get a picture of mine for you.
Edit: Redheartbeat "beat" me to it...gotta love dialup.
my 06 6.0 had the engine oil cooler option.
I ditched it and put a blockoff plate.
86 C10 6.0/4l80e
The oil cooler adapter bolts to the side of the oil pan just above the oil filter.
Thanks, I rememeber that now.
