Results 1 to 4 of 4
Thread: OK the 6.0 is in...catch can question?
    Feb 2006
    MIZZU
    I got the truck running with the new 6.0 and the 220/220 581/581 115lsa cam.
    Thanks Jamest for the recommendation and Allen for the cam and springs.
    I just went and drove a couple soft miles and the STS valve cover boost block off is blowing oil out the filter cause the switch isn't shuting all the way.
    What is the best way to eliminate this?
    Catch can hooked to both valve covers with a breather, or just 2 breathers on the valve covers(seems like they still might fling a little oil from boost blowby in the crank case.?
    This 6.0 doesn't have a PCV valve anymore because it is an '06, so I think boost is always going into the drivers side valve cover, and like I said above, the STS switch isn't working on the passenger side.
    Thanks, TY
    1999 Silverado Z71 RCSB with 2006 LQ4 6.0, Comp Cams 220/220 581/581 115lsa, STS, methanol, Nelson street tune, 160* stat, 2006 E-fans, FLT 4L60. 12.53 @ 107 on 5psi
    Oct 2007
    connecticut
    i'd say get the problem solved first, then decide where u wanna go from there. prob just need two breathers.
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Uh...I might be going out on a limb here, but fix the switch on the STS valve cover boost block off? And the catch can should be fine by hooking into the valve cover breather lines. And why not just have the BOV release into the atmosphere? Does it have to be recirculated into the intake?
    Feb 2006
    MIZZU
    I don't have a BOV yet, but I'm just wondering if I can get rid of the STS boost blocker or does it control something else as well and tohse of you running the STS kit, what do they do about newer trucks with no PCV?
    =TY
