Results 1 to 3 of 3
Thread: HELP>>>>TRANNY!
    Feb 2004
    Homer Glen IL
    My truck still does not want to move in drive. I checked and checked and checked the fluid in it and I am sure it is not low. It goes just fine in reverse. When i pull it into reverse you can feel it engage. But what i put it in drive it does not feel the same. When I push on the gas the rpm's come up some and it barely creeps forward. It feels as though it is slipping but I dont know why it would seeing as how it was fine untill i changed the pan. Is there any explination for not going in drive but acting fine in reverse. Could I have cut a wire along side the trans or pulled one out? I need help. I am supose to dyno in a week.
    2004 Cosmos Purple Metallic M6 GTO
    2000 Silverado *not stock* 340 rwhp 418 rwtq
    1989 Chevy Corvette *mint*
    1992 Buick Regal *beater*
    www.9handsracing.com
    Are you not showing any Service lights? Are you sure you did not disconnect any connectors when installing the new pan? It sounds like you are low on fluid pressure which leads me to think you knocked the connectors loose on the valve body when doing the install. Have you attempted to check the fluid pressure? My ATSG manual says it may be a torque convertor but if you can drive backwards fine I would not think convertor. If you get a code I can tell you what it is.
    Did you remove the valve body for any reason?
    If you removed the main electrical connector from the transmission, you could have damaged pins. The connections are highly important and will cause problems if not making the proper contact.
    Dec 2003
    check all your connections and your solienoids
    old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
    New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
    future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
