Results 1 to 7 of 7
Thread: exhaust flange
    Jun 2007
    maine
    exhaust flange
    hey guys i need a set of exhaust flanges for my factory manifolds on my 02 5.3 do you think many junk yards would cut these off before the cat if asked? i just need the section thats about 10 inches or so with the o2 bung on it. can i possibly get them elsewhere? i need ASAP suggestions would be AWESOME! thanks!
    Do you have any performance truck shops around your area? Go ask them if they have some take-off pipes you can cut the flanges off of. Salvage yards usually send the flanges with the take-out engine. You could trace the shape of the manifold flange onto some cardboard and then go to a weld shop and have them burn you out a pair from 3/8" plate. Then all you'd have to do is get pipe welded to them and drill some holes for the bolts. Oh yeah, gaskets.
    Buy some long tubes and you don't have to hassle with the flanges.
    Jun 2007
    maine
    yeah i dont think there are any performance shops around here 8( i would love long tubes but lance hasnt finished them yet.. this 5.3 is in my 1998 SBRC... so there are no lt's are far as i had heard... i may have to have them cut out i suppose... if i cant locate any at a junk yard.. thanks for the suggestions.
    Jun 2007
    maine
    say i do go the route of making my own flanges what size exhaust piping do i need? and id have to flare the ends correct? and do both manifolds have those half circle rounded inserts in the end or just 1 side? only one of mine has one.
    I used flat paper gaskets on both mine with the fbody manifolds, no doughnut gasket. No flaring required, just weld pipe directly to the new flanges. You could be slick and weld the pipe inside the flange though.
    Jun 2007
    maine
    yeah that sounds much easier that leaky gaskets i guess ill go that route...what size exhaust pipe do the flanges use any idea?
    2.25" I think. Measure the opening in the manifold and try to get ID tubing close to the same size.
