Results 1 to 5 of 5
Thread: 408ci engine?
    Feb 2008
    Arizona
    408ci engine?
    hey buds.. i've seen a couple of you guys running 408ci engines.. im interested on them but im not sure what you guys are talking about...
    is this the same kind of engine you guys are running? eBay Motors: 350 Chevy 408 Stroker AFR Crate Engine by NASCAR Shop (item 380026732194 end time May-21-08 07:57:45 PDT)
    would this engine work in my truck? can i do a turbo setup in that engine?? how much hp can i expect? thanks!!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    That's from an old 350 base motor. Your looking for a LS base 408 like this 408cid LS1/LQ9 Iron Stroker Long Block
    An LS based 408 with 10.5:1 compression would net you about 500HP at the crank with decent flowing heads and a good cam in the 230 duration/ .600" lift range.
    Mar 2006
    Phoenix, AZ
    The LS based 408's are a 6.0L block (LQ4 or LQ9) with a 4.030" bore and a 4" stroke crank.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    Feb 2008
    Arizona
    Thanks guys!! Im really interested in one of those, but i need to consider the cost of a 4L80E... So, from the price at texas speed from the DBTBSS link.. how much do i need to add to get one of this monsters running..? do i need to change everything from my truck(harness and that stuff)?? thanks again..
